2N Starter ????
nashranch
This guy he has a rebuilt starter for a 2N...I've never seen one like this before.
https://portland.craigslist.org/clk/grd/d/ford-2n-9n-8n-freshly-rebuilt/6331200233.html
I could be wrong, but I think hes mistaken. That's a pump or plow motor.If not I'll learn something too. jstpa
Winch motor. Note the three battery cable terminals. Does forward and reverse. The spline shaft fits into a worm which turns the gear that drives the drum.
I concur with the others -it is NOT even a FORD starter, let alone a FORD TRACTOR starter. All 9N and 2N starters never had a solenoid and used a 1-wire connection for one. This one has two posts, has TORX barrel/field coil securing screws -never around then either. The guy is obviously mistaken -he may have had it rebuilt but it was never on his 2N Tractor.
ORIGINAL 9N/2N STARTER w/o SOLONOID:
ORIGINAL 8N STARTER w/SOLONOID:
Tim Daley(MI)
