8N hydraulic problem
Roger in Iowa
With the position control pointing up lift works okay.
With the lever in draft position lift doesn't want to work, but if I hold down on the front of the little lever it seems to work okay. Is there some external adjustment I can do? Or do I have to remove the top cover?
(quoted from post at 22:55:29 09/29/17) With the position control pointing up lift works okay.
little history of the problem development would be helpful, but it is not likely that an external adjustment will fix it unless loosening the 4 quadrant bolts & sliding it fore & aft will do it.
I have no history on the tractor or problem. Bought it to resell. Lightly used as the clutch pedal shows very very little
wear.
(quoted from post at 09:52:19 09/30/17) I have no history on the tractor or problem. Bought it to resell. Lightly used as the clutch pedal shows very very little
wear.
would try 'easy' first. Loosen the 4 quadrant bolts & slide it fore & aft & see if either way fixed problem. Put a scribe mark first so you can put it back to where it is if not successful.
