Need help on ajusting 8n clutch/brake pedal
rwt101
I did a search but I suppose I didn't hold my mouth right, I didn't find what I wanted. I just replaced the rear axle seals and new brake shoes. I also welded up the worn spots. I need to know how to adjust the clutch/brake pedal. I have the clutch set at about 3/4 free play. Also it doesn't seem like the brake is being pushed when I push on the clutch pedal. I know I should have a manual. Can't afford it right now.
(quoted from post at 18:21:40 09/25/17) I did a search but I suppose I didn't hold my mouth right, I didn't find what I wanted. I just replaced the rear axle seals and new brake shoes. I also welded up the worn spots. I need to know how to adjust the clutch/brake pedal. I have the clutch set at about 3/4 free play. Also it doesn't seem like the brake is being pushed when I push on the clutch pedal. I know I should have a manual. Can't afford it right now.
There is no connection between the clutch pedal and the brakes on an 8n.. If you want brakes you have to push on a brake pedal.
I must have been looking at a 2n or 9n then Both brakes are on the right side. OK just a senior moment.
