mcleveland
New User
first off thank you for looking at this and your help !
im new to tractors and have a 9n , I rebuilt the hyd pump and had the pump valve with out the notch at the end . worked fine for 20m then stopped working , found the gasket for one of the sides on the pump blew out . do I have the wrong pump valve ??? should I be using the one that is notched at the end instead of the full circle one ? here are pics of my pump if that helps anyone. thank you very much for your help
