Help, I'm working on this 8N tractor with front mount distributor. It has fairly new points and condenser, points are not pitted, bushings have very slight looseness, about 1-2 thousandths, points set at 0.015" but I can not get the time set per instructions (1/4" from edge of mounting hole). To get time set to this mark, I need to remove timing lock screw and move point plate past the slotted adjustment hole in the housing. Of course, doing this moves the contact point for the coil so far out it will not make contact. What in the world am I doing wrong. The timing procedure seems so simple, I can't be doing it wrong. Is it possible it has the wrong points in it? They look correct. Point plate looks exactly like the one sold by Yesterday's Tractor Co. Web catalog. I haven't changed any parts yet, and the tractor isn't running at this time. Thanks in advance for any assistance!
