Hello, I'm new to join but have read posts for a long time. I've got a tractor that has me pulling my last hairs out!! :shock: :?
1948 8n front distributor
12v converted
motor rebuild less than 100 hours.
Only use to bush hog 3 acres and drag driveway.
So, Tractor was running fine,started right up,ran good through rpm range. I just started the bushogging this year but have owned the tractor since 1999. At the end of the last bushhog job I noticed something didnt sound quite right,like it couln't get to full rpm. I cut in 1st gear with a 5' bushhog. Anyway I get done and park it under a cedar tree at the house then Hurricane Erma's remnants rolled in(im in Middle Tennessee). We got 6" of rain over 3 days with temps in the mid 60's. After the storm no spark,dried the distributor enough to start it and move it about 6 feet and it died.Long story short I went through everything electrical,new plugs,wires,coil,cap, rotor,points and even a new distributor. Gap at points is .015 plugs.025. Checked fuel flow and changed bowel screen and elbow screen,blew compressed air up fuel line to clean out intank screen. Then I rebuilt the carb after soaking it 24 hours in carb cleaner. I got it all back together and it would start and idle ok but would backfire and popcorn at higher rpm.At that point I noticed I had a blown manifold gasket on#4(toward steering wheel) Fixed that and put a new carb on it,now it starts and idles fine but still stumbles and backfires at high rpm unless I pull the choke out a little,then it runs fine. Idle needle was turned out 1.25 turns and I messed with it to get a good idle. The main needle started at 1 turn off bottom and nowhere in its range could I get it to run good at high rpm without choking it a little. I drained every bit of the gas out last night and put it in the truck to burn it up(about 4 gal) and am gonna get 5 gal of straight gas today treated with stabil and see if thats the problem but the gas was new at the last cut. If new gas don,t do it where do I look next????
12v converted
