I am new to 8N tractors... I was wondering what is the normal range of travel for the hydraulics? Looking at pictures and videos online, it seems that mine doesn't lift as far as some of the ones I have seen. With the bush hog mounted it doesn't lift very far off the ground... but it does not leak down very fsst... if I leave it up... it will stay up for an hour or so.. will be back on the ground overnight. without anything mounted.. I can stand on the lift bars and they will not budge... (300+ Lbs). When at full lift, I can lift higher by hand.
How is this measured? angle, or inches off the ground?
