ok so after 2 hyd jacks...one on each lift arm on the housing and a big pry bar on the back where the draft spring is it finally popped loose...I have gone through it and am putting it back together...questions I have..the ring package..(3 steel rings) show 1 and 2 ring with bevel toward bottom and 3rd ring with bevel toward top of piston so that's how I installed it...sound ok?...second I have the gasket that goes between the cyl housing and main casting with 3 holes...then 2 separate paper gaskets that look like washers...when I separated this it had all of them between the front of cyl..my assumption is the 2 washer looking paper ones go between the rearmost bolts and the 3 hole long one goes under of course the front part of the cylinder...would this be right...im almost there so getting pretty excited...yes I did hone the cyl and no I didn't put in the naa piston as some guys said if there are lots of scratches in the cyl it would eat the oring up...as I bought this stuff before I could get the top off so it would be here to reassemble I wasn't able to assess the cyl walls so its going back like it was...thanks again for all the great advice and help...have a good one
