9N runs better w/choke out 1/2"...
Trying to help my Dad remotely on his tractor. 9N, front mount dist, 12 V.
He discovered while pulling our finish mower that he gets more "speed/better rpm's and that the tractor runs better with the choke pulled @ 1/2" out.
I am assuming this means the tractor is running "lean" as adjusted, and pulling out the choke restricts the air mixture, so I need to adjust the carb to allow more fuel?
Any suggestions?
Mike
first thing i'd check is fuel flow. with the sediment bowl valve open and the plug removed from the bottom of the carb, the flow should fill a pint jar in 2 minutes.
My 2N literally would not run at all without having the choke halfway out when I bought it. I had to adjust the carb a LOT to get it right. Runs amazingly now.
The choke should only be needed when starting. If the tune is way off, choking it is just the same as adjusting it to run richer. What I had to do is adjust the carb main screw to make it richer so I could back off the choke while driving. I adjusted it richer until I only had to use the choke when starting and as soon as it started, I could release the choke and it would stay running.
Pulling out the choke gives you a richer mixture. So, you could have either a fuel or spark problem.
A carb out of adjustment will also cause this problem; set the main jet at 1-1/2 turns out & leave it alone.
A dirty carb can cause the problem as well; start by cleaning the fuel screens. (see tips 45 & 56)
Dirty/old gas, or water in the gas can cause this problem.
Restricted fuel flow can cause this problem; remove the bolt at the bottom of the carb & check for flow. The flow should fill a pint jar in under 2 minutes.
On my 1950 frontmount, needing choke to run is the first sign that the points need adjusting/replacing.
A vacuum leak can do the same thing. Get a hand propane torch and carefully spray it (unlit of course) around the intake manifold at the carb to manifold interface & the manifold to block gasket of the tractor while it is running. Or, you can use carb cleaner or WD40. If it speeds up, you found the leak. Sometimes (rarely) manifolds crack or get rust holes.
Lastly, when all else fails, you could have an air leak around the carb metering section. The likely suspects are leaky throttle shaft seals and/or a worn throttle shaft. Or, just a real dirty carb w/ clogged passages.
Bottom line: Probably 90% of "needs choke to run" problems are fuel related, but do not rule out ignition problems, contrary to what others may tell you. I?ve had that very same problem before w/ a rebuilt carb, fresh fuel & good flow & a tight manifold.......and it was a spark problem. But, that was unusual. Just check the likely fuel problems first.
Please be sure to post back & let us know what the fix was. We all learn something if you tell us what worked!
75 Tips
