Fuel out air intake
swhockett
Putting things back together after several months doing a valve job. When I opened the fuel line gas began leaking around the air intake hose. I haven't done any work on the carb but am assuming the float is stuck allowing the bowl to overfill? Appreciate some advice.
Am I going to need to disassemble the carb completely or after fuel sits do floats become lubricated and start working. I don't have a carb rebuild kit on hand.
(quoted from post at 09:22:42 08/12/17) Am I going to need to disassemble the carb completely or after fuel sits do floats become lubricated and start working. I don't have a carb rebuild kit on hand.
ometimes, a sharp wrap to carb with a wood or plastic tool handle will free it up & stop that flow. Otherwise remove bowl to access needle/seat/float. If real careful you can save gasket for re-use.
The carb leaks on my tractor sometimes, but the tractor runs great,
So I just be sure to cutoff the fuel each time I stop the tractor for any length of time, yes it can be a pain, but rebuilding the carb is no guarantee you will stop the carb from leaking and tractor might not run as well, as it does now,
Also I added an metal inline fuel filter between the cut off and carburetor, that stopped more of my fuel related problems then anything else I have done,
However my carb does not leak fuel as soon as I open the fuel cutoff, that problem must be fixed,
