ok so tractor went into the shop yesterday and I drained the hyd oil...took out all the perimeter bolts...removed the seat..detached the 3rd arms and took off sidecovers and unhooked linkage as you guys suggested....put a bolt thru a chain to one of the seat stud holes and hooked up the cherry picker and nothing...then I got a landscape timber and applied pressure to the boss next to the lift arm and bounced it on both sides...nothing came loose...then hooked chain around the lift arm boss(as close to the casting as possible) and put hyd pressure on it with the picker...tried to drive a small screwdriver between main housing and the top casting to no avail...hit repeatedly with a 3lb dead blow hammer and nothing has moved...im at a loss...I foresee breaking the casting if I get rough but am wondering if somebody glued it with indian head or something that sets up like that..i thought the hardest thing to do was unhook the linkages inside and now this...any ideas or suggestions?...thanks for any help
