fixing brakes on a 2n or 9n
deene
ok so I got great advice from guys on here concerning the draft arm problem and want to tackle the brake issues while I have it in the shop...how does the wheel hub come off?...my grandfathers had 2 large nuts that came off and then the hub would come off....also are seals readily available?..thanks for suggestions and help
[b:1f894777dd]"Huh! I didnt know the Ns had brakes!"[/b:1f894777dd]
mine doesn't have brakes. mine has brake.
Google How-To-Replace-Brakes-on-a-9N.pdf should be the first hit:)
Also if you do not have one get the I&T FO-4 Ford Tractor Service Manual.
It is somewhat of a PITA, so do it right the firs time. Don't want to do it again:)
