9n wiring harness
Texag2002
New User
Had the wiring burn up on my 1940 9N. Trying to replace it and having some difficulty figuring out what harness I need. It is converted to 12v. Harness 9N14401C looks right, but says it is for 6v system only. I found a 8N14401B but it doesn't look correct either. I can cut it in but I really want to fix this right instead of rigging it like the last one. Any help is really appreciated.
6 are 12V don't matter you can make either harness work...
I prefer the 8N harness myself. Fish for JMOR wiring diagrams I think he has a diagram using a stock 6V harness.
There are several different ways to convert to 12 volts. I doubt
you will find a harness that will work without modifying it.
General way to do it using a original replacement harness. Sorry don't have a 9N diagram... Either way you are taking the regulator out use those wires to your advantage, Complements of JMOR his work not mine...
Amp meter is of little to know use install a voltmeter in its place...
Nuttin wrong with using a replacement harness its cheap, efficient and neat...
