2N front rim options
Tony292
From reading on the interweb, I know that the 42 2N only came with the 19 inch front wheels. Or the steel wheels, but that isn't what I am asking about.
Mine seems to have a hybrid, welded together front rims. It seems someone has in the remote past, cut out the 19 inch center sections and welded them into 16 inch rims. The welds look crappy but seem to be structurally sound. I am the third owner. Original owner was 90 plus years old when he sold the tractor so he is probably the culprit!
What I want to know is if any aftermarket company sells a 16
Inch rim with the 1942 5 bolt pattern? If yes, then I'll buy, if no, then I'll keep these hybrid rims and grind, weld,
And keep these running! It has brand new 16s on the front! So I don't want to throw away perfectly good tires.
They are Ford Deluxe rims. I had a set on my 2N.
The previous owner drilled new holes in the hub to mount them on mine.
Yes, there were 16 inch rims made. Hard to find now.
I snagged this set on a parts tractor I bought.
Had them sand blasted and then primed them.
Haven't got around to painting them yet.
Here is a close-up picture of the rims on my 2N.
The mounts on yours appear to have been modified to fit.
Your rims are off a '37 ford deluxe car, as stated. The hubs off a 9n/2n will not fit the car rims so your PO welded up a center to make them fit the 9n/2n hub. There is no
aftermarket 16" rims for the 9n/2n Only hard to find used ones. Another option would be to change out your hubs to an 8n hub and then you could buy the aftermarket rims. You might
also consider adding tabs and a hub cap to your existing rims to it to dress it up as on my '43 in the next photo.
Kirk
Them there pups look like the hubcaps used on a 1936 85 hp car...the same ones used on the 1937 FORD V8 Experimental Prototype Tractor, owned by Dick Cummins, and shown in most of the FORD TRACTOR books.
Tim *PloughNman* Daley(MI)
The brakedrum and bearings off these 37 Ford V8 rims fit on 9n and 2N hubs. Have a machines machine off the brake drum and nobody will notice the difference. I only have one V8 hubcap and "beauty ring', so I do not use just one, wod consider purchasing or selling. I run 600-16 mutirib 6 ply on the front to support my Dearborn J1 bulldozer.
Charles Krammin
Hastings MI
