Have a early 8N with starting issue, bought it at an Auction as not running. Here the situation: Have good Compression 115 to 125, have spark, points are set to spec, have Power on the new Coil, Ignition Wires are good and Plugs are new. Motor seem to have 4 new Piston align mark points to Cylinder 1, Motor has also a new Cam and the Timing Marks seem to be correct. When timing Marks agree between Cam and Crank Cylinder 1 is around 25 degree before TDC. At this point both Valves are closed no play and movement. The only thing to fix and set is the carburetor but it should fire at least with starting fluid and it wont. A carb from a working 8 N has the same behavior. I'm out of Ideas and it makes no sense to me not even getting a misfire or some kind of a life sign on this Motor. Has somebody experienced something like this, has a previous Mechanic pulled a dirty trick with the timing on me?
