Hey y'all,
Here's the results. Double checked all valve adjustments. One was very slightly off, so it was adjusted and only gained 10 psi on that cylinder. All other valves checked out ok.
We ran compressed air to the dead cylinders and had lots a air entering the crank case with both valves closed. So it looks to be a ring job at the very least as I had initially suspected. Bummer.
Anyhow the original question remains unanswered and am asking advice on things to look for during the tear down ... that is what would cause such a drastic damage to rings? At the moment without having torn motor apart I would guess an oil pump falure of some type? Any suggestions anyone? Anybody have a way of testing the oil pump once off the block?
Thanks again for all the help and great advice[/code]
