Hey sparkiemiester!!! I'm totally stumped and need your expertise. Working on trying to get a 9N running for somebody. Was sitting over a year. Here's the info...
12 volt negative ground.
New battery fully charged, new neutral safety switch, new key switch, new OEM dash resistor, new ceramic blob resistor. Starter motor turns engine over fine. Getting 12V to coil. New points gapped to .015... blue streak brand good stuff. New condenser, good copper strip to connect points. New coil. Verified by test lightthat points are opening and closing. New plug wires, cap and rotor. Pig tail on coil is making contact on brass screw and metal bendy tab is making contact on cap metal spot. Wired firing order 1,2,4,3. And I have spark that will jump 1/4 inch gap bright as the sun all day long... and of course new auto lite 437's gapped to .025. Tank was drained boiled and rinsed with gas and drained and re filled with fresh gas. New fuel line, sediment bowl and carburetor. We have positive strong suction on carb verified by hand hickie over air inlet. Choke is working. Pull the plug out the bottom of the carb and nice steady flowing stream of fuel.
The symptom is that as I hit the starter button engine turns over and rumpa rumpa .... and one pop backfire out the carb and that's it.
What am I missing? The only thing I did not check is for engine compression.... my gauge broke the other day but this tractors engine was just re built not too long ago (5years or less). So I assume it to be over 90PSI it does have enough to blow my finger off a sparkie hole.
For the life a me this one has got me stumped?! Any ideas or suggestions you could offer would be super!
Thanks o great sparkiemiester!
