massey 35 dozer blade fit/work on 8n?
Floating through the ole CL today and saw a Massey 35 for sale with a dozer blade. Got me to wondering if it would fit/work on an 8n??? If so have no idea what a fair price for just the dozer blade itself would be. Here's the link, not many pics that would help me see how it connects... as usual not mine just one I saw on CL: https://fredericksburg.craigslist.org/grd/6163856725.html
For the 8n it's not a bolt and go. It's likely you would have to rear bracket to hook up to the tractor as I have done with this 19-80 frame on my 8n. The blade on the 35 is a dearborn and the frame maybe an ARPS or homemade. Also it is run off a 2 way cylinder. You would have to run a line off the test port on your 8n which will give you power pressure up and gravity down, which is ok for snowplowing. You will also have to chain down the 3pt arms to divert the hydraulic fluid. All in all it can be done if you want to do some work and could get it at a reasonable price.
Kirk
Sell the N and buy the Massey.
The 35 Deluxe is in the same league as a Ford 3000. A better machine than any N.
Live hyds, live pto, dual range 6 speed, 37 hp. Then you know the blade will fit:)
