47 8n front wheel bearing seal
pixer
Front seal leaking on my 8n . Manual says drive rear bearing and seal off and replace seal. I just want to change inner seal, is it necessary to drive bearing and cup "race" out just to replace inner seal. Bearing seem good but losing lots of grass
(quoted from post at 13:20:29 06/27/17) Front seal leaking on my 8n . Manual says drive rear bearing and seal off and replace seal. I just want to change inner seal, is it necessary to drive bearing and cup "race" out just to replace inner seal. Bearing seem good but losing lots of grass
No , you do not need to removed the race . Reach through the center and lightly tap the bearing and it will push out the seal . Remember the seal keeps dirt out and rides against the spindle lip .
They make caps with grease zerks built in . I push grease through my bearings until it pushes out any old dirty grease . It makes a mess but she aint a looker anyways .
thanksforthrinformation ken I'm very cautious when doing these jobs I'm prone to use a jack hammer when a tack hammer will do.
