2N wiring harness
rapidfire
Putting a 2N back together and I bought a new wiring harness for it. Does the two wires for the generator and the coil go though the spark plug wire tube to the front or not?
(quoted from post at 08:04:26 06/27/17) Yes
75 Tips
Thanks Bruce. I'm using bolts instead of the studs that you have suggested in other threads. Do you leave off the washer where the tube and governor bracket attaches?
HHHMMM...a 2N should have a 1-wire/3-brush generator. Only the early 9N-10000-A small generator had two wires. Are you using the round-can cutout too?Can you post pictures?
Tim *PloughNman* Daley(MI)
