technoamish
New User
Ok All, I took your advice and started a new message. For those who haven't been following this issue, I was moving some dirt with a 1/4 yard back bucket and heard a pop noise. I tried all the gears and the 2N didn't move just acted like it was in neutral. One suggestion was to check the differential ring gear rivets. I removed the left side axle and inspected; everything looked fine. the next suggestion was to check the Coupling Assy - transmission to pinion.
I just removed the right side inspection cover and mystery solved!! the Coupling shaft has broke in half. Ultradog MN & royse you nailed it! Looks like I'm going to have to split the tractor to replace.
Here's the funny thing normally as you mentioned these don't tend to break. Weeeeellll, Previously when I was having some hydraulic
issues I installed the lift cover and the piston connecting rod had dropped down on the coupler. I didn't realize that I had done this.
Well I had mowed the lawn and drove the tractor around a bit before I corrected that issue. It must of scored the coupler causing a weak spot and that's where the coupler snapped in half.
Hey royse, It looks like your about 2 hours from Lapeer. I'm going to see if anybody around here has a coupler. If I can't find one in Lapeer I'll be coming out to see ya. Thanks for all your help everybody, and wish me luck cracking that thing in half!
