Checking to see if I got have this correct. A while back in an emergency I jumped the open resistor on my 2N to get a few post holes drilled. Ordered a resistor from Yesterday's Tractors and forgot about it. Today the tractor just died and suddenly my memory came back with a DAMN! I towed it to the barn, installed new plugs, points, and condenser and then the new resistor. The tractor fires right up but when I went to check my voltages I have 6 volts on the coil all the time the ignition is on. I checked the resistor, it has 6 volts in and out. Shouldn't it be lower? Is it adjustable?
Thanks,
Mark
