Wiring of key switch and push button
MGBlaster
New User
Converted my 9n to 12 volt but can not figure out where the key switch wires connect too or the push button wires connect
(quoted from post at 21:27:00 06/22/17) Converted my 9n to 12 volt but can not figure out where the key switch wires connect too or the push button wires connect
Your key switch turns the power on / off to the coil and it is part of the ignition system .
The push button is a GROUND that grounds the one small terminal on the inside of the solenoid to complete the electrical circuit and turn the starter over . You do not need to send power to the solenoid since it is built to get it's power internally . This is opposite of how typical Ford in the 60's up did it so it can be confusing .
The key switch and the starting system do not connect . They share a battery and that is all .
"The push button is a GROUND that grounds the one small terminal on the inside of the solenoid"
Sorry, not on a 9N. The push button on the transmission cover ona 9/2N has a mechanical linkage to the starter switch which on the engine
side of the steering column.
For the original poster. Google wiring diagrams by JMOR.
have u yet determined which model of N u have? there are significant differences in the wiring between 9/2Ns and 8Ns.
(quoted from post at 07:34:29 06/23/17) "The push button is a GROUND that grounds the one small terminal on the inside of the solenoid"
Correct , I peeked in before going to work and had not had any coffee yet . My brain was thinking about wiring a push button and I total missed "9N" :oops: It could still have solenoid wired in ?
