Copperhead don't play
8N with side distributer, spark will jump 1/4", compression 120,120,90,120; but will not start. Located compression on #1 cylinder, wired plugs for rotator button to # 1 cylinder, wired 1.2.4.3, will hit, but will not hit the second time, swapped carb with rebuilt one no luck, rewired number one to number 2 wire on distributor, then rewired number one to number 3 (in other words moved wires one place forward then one place backward), still will not start, tried starting fluid every time dried plugs with propane torch between trials. This one has me whupped. Need help from YT experts. Thanks,
