Tall T
When the ORC is on by itself, is it common to have lots of wiggle room from the point of the split pin, even though the spline feels right? It spins fine when engages and by itself.
Also, where the shaft U-joint connects to the ORC, there is just the spring loaded lock pin, but there is also another hole passage as though another pin should go through the hole in the ORC.
the holes aren't threaded for zerks. Are they intended for push type grease guns or Grade 2 bolts?
When one has the spring loaded push pin, is that all that is necessary?
Thanks,
Terry
Any visible brown juice is coincidental; only the product name has been withheld to protect the innocent.
Thanks,
Terry
