Skunkape52
New User
I've read many posts and helps for my problems but just want to run it by you guys for specific comments.
1952 8N 12v (6v can coil) side mount distributor MS carb.
Been having a terrible time trying to get it started.
Was running great before parked about a year ago. Fresh gas and good flow to carb. 2 yr old cap rotor points and wires in good shape. Cleaned plugs and good spark all cylinders.
Since I had good spark and good fuel flow it had to be the carb. Removed carb and cleaned twice then rebuild kit 3rd time. Popped right off but would only run with choke, then started loping and quit.
Ran down battery turning it over so jumped it from my truck and it started again after several cranks only to run with choke. Was going to check for vacuum leak at intake on next start but now all of sudden I have no spark.
Did I burn up the coil with the truck? How do I check it? Condenser maybe?
Cap, rotor plugs, points and wires are all good.
It has new voltage regulator. Had to replace it earlier when tapping it would not disengage starter.
