SLWagner73
So, on my 2n I have replaced the safety valve, put a new piston and o-ring, with the backer in correctly.
And finally, after some helpful advise from some gentlemen on here, got the silly control valve back on the arms. I put everything back together, and voila, the arms come up nice and smooth, and everything seems fine...
Until I hooked the scoop up, and now, the only way to raise the arms is to take all the pressure off of the top link. I screw the top link all the way out, so there is no "load" on it. And the arms come up.
Soon as I have the arms up, I can draw the top link in, and it stays.
But this sure isn't very efficient.
I am going to order a new gasket kit, cause I'm sure I'm gonna have to open it up again, and I was thinking maybe someone knew what else I should replace.
I don't think it's the pump, cause that felt go, and moves the oil fine. And I'm not seeing any "blow-by" at the piston.
Any help or ideas sure would be appreciated.
Scott
Scott
