1951 8n Gear Shift
mlbrantley
New User
Trying to replace the gear shifter on the shifter assembly on a ford 8n 4 speed (1951). Have remove the assembly, the starter button and am trying to separate the gear shift from the assembly. Can't figure out how to remove it and the spring for replacement. Any input of help will be greatly appreciated.
Mike in Alabama
jmor thanks for being helpful. The spring is actually broken, with the lower, smaller end up and inside the bigger end. There is no sign of the seat (7228). Just want to get the shifter out of the assembly. The latch (starter saftey).
JMOR based on your comment, I revisited the problem and sure enough the seat was still in there, just hidden. Thank you for taking the time.
(quoted from post at 08:37:21 06/12/17)
ou are welcome!
