I just purchased my first tractor... ever. It is a 1950 ford 8n with a side mount distributor. It is now running well and has been cleaned of deposits fairly well as well. It came with a draw bar and stay bars. I removed them to check and see if the 3 point would work and sadly it doesn't. I have the pto running and I have tried the draft control lever in both positions neither seem to make any difference. Someone has previously plumbed in a valve for some reason or another and I'm not sure if that is affecting it? I don't have any previous experience with tractors but plan to learn all I can by doing the work myself. I'm getting ready to drain the rear end so that tomorrow I may take of the inspection plate and be able to answer more of what I'm sure I will be asked. All help is appreciated.
Thanks,
Sean
Thanks,
Sean
