(quoted from post at 18:21:39 06/09/17)
PTO Shaft - PTO Shaft. For 8N, 9N, 2N (converts 1 1/8 inch shaft to 1 3/8 inch spline. This is the shaft only. (Part No: 9N710-38)
$59.37
Do I need this too? Shaft bearing?
PTO Shaft Bearing, Front - For tractor models: Dexta, Super Dexta, NAA, Jubilee, 501, 600, 601, 700, 701, 800, 801, 900, 901, 2000, 2110LCG, 2310, 2600, 2610, 2810, 2910, 3000, 3400, 3500, 3550, 3600, 3610, 3910, 3900, 4000, 4100, 4110, 4110LCG, 4400, 4500, 4600, 4610, 5000, 5600, 5610, 5610S, 5900, 6600, 6610, 6610S, 6700, 6710, 6810, 7600, 7610, 7610S, 7700, 7710, 7810S, 8010. All WITH 1 3/8 INCH DIAMETER PTO SHAFT. WILL NOT FIT 1 1/8 INCH DIAMETER PTO SHAFT. (Part No: E75GE9)
$8.28
PTO Shaft Conversion Assembly - Shaft Assembly with cap converts 1-1/8 inch PTO System to 1-3/8 inch. Assembled and ready to install by removing 4 bolts from cover. Length 30-7/8 inches. Uses gasket C5NN747A (included). (Part No: 9N700-38)
$83.21
