dan1953ford
New User
Need some advice on where to start with some recent engine problems with my 1953 Ford NAA tractor. Recently while bush hogging the lower pasture, I started to loose power while mowing with the P.T.O. engaged, so I returned to the barn. Sounded like an ignition misfire so I put in new plugs, points, condensor & rotor. It started, but worse than before and runs very rough, little power & just chugs along in 1st gear very slow. No power at all. Replaced fuel filter & it is getting fuel to the carb. What should I check next? The carb? Any help appreciated. I need to get more mowing done.
