This message is a reply to an archived post by JMOR on May 14, 2013 at 10:41:52.
The original subject was "Re: FORD 9N Governor issues?".
Hello, I have a 1941 9n. I have replaced the carb with a new one, complete new distributor assembly, and govenor. My issue is that I can not get my engine to rev up. I can manually do this by moving the arms on the governor, but the governor will not do this on it's own. Although I do not have a tach, I am assuming I do not get much over 1000 - 1200 rpm. The connecting rods to the arm on the governor and the butterfly on the carb are not binding up, so this can not be the issue.
Does anyone have any suggestions? My old governor would at least allow me to run at a higher rev level: but needed replaced as one of the balls inside came out of the housing.
