Sherman Transmission
kim7253
New User
rebuilding a sherman combination transmission and need to locate a counter shaft C0NN7111B. Does any one know where we can locate a new shaft or good used shaft. Mine is not pitting yet, but ir is worn.
I would try Long Lane Tractors at 717-367-8610 or http://www.lltractor.com/default.htm. Ken was able to supply me with the Sherman parts I needed. Of course their inventory will vary.
I do have a good used shaft if you're interested
Your counter shaft is for a four speed Ford transmission , 8n711 . The poster needs a counter shaft for a Sherman three speed which is similar in number conn7118b .
edit , wrong number .
Your counter shaft is for a four speed Ford transmission , 8n7111 . The poster needs a counter shaft for a Sherman three speed which is similar in number conn7111b .
(quoted from post at 18:43:18 06/08/17) Your counter shaft is for a four speed Ford transmission , 8n711 . The poster needs a counter shaft for a Sherman three speed which is similar in number conn7118b .
oh ok..he posted 7111B
