technoamish
New User
I'm hoping somebody with knowledge of the 2N/9N hydraulic system might be able to help me out with this one...Last fall I replaced the "Ram cylinder, piston and rings) & rebuilt the Hydraulic pump. Tractor worked great all winter and spring. About a month ago I was using a 1/4 yard back bucket moving dirt. I was aggressively backing into a dirt pile picking up some what heavy loads and moving them around. about an hour into it the lift stopped working. I tried adjusting the control spring on the back of the Lift cover; didn't help. I removed the lift cover and hydraulic pump. With the lift cover on the bench I moved the touch control lever up and down and It seems to be working fine? I disassembled the Hydraulic pump examined all the parts put on new gaskets and pump relief valve, i reinstalled everything back on tractor and lift is not working. When i look through the inspection hole "with tractor running and PTO engaged" and I lift up on the Touch control lever, the Control lever fork does not move far enough forward to push the Control Valve into the pump. Something is keeping the Control lever fork from moving forward enough? Any Ideas?
