svrunyan4075
Is there an absolute first source Ford 8n 12 volt wiring diagram I should use? And should all the wiring be 12 awg or various guages?
I see there are many 8n 12v wiring diagrams from various generous users that pop up on this forum and the internet. I also see some list various gauges on various connections and some do not, leading one to think the wiring is all 12 awg.
I would like to double check the compete tractor wiring. I also recently bought an 8n and the headlights and rear lights are dim. Though the headlights are wired in parallel with 12v bulbs, I think it may be incorrectly connected to the resistor block and the headlight ground probably needs moved from within the casing back to a more solid ground.
Thanks for any assistance and suggestions!
