8N running on 2 cylinders, need to make hay!
#3 and 4 are not firing at all, though they have spark.
Compression test results:
(cold, dry, throttle wide open):
#1-105, #2-95, #3-89, #4-100
(cold, with oil in cylinder)
#1-135, #2-115, #3-110, #4, 100 (#3 blows oil mist out sparkplug hole while I test #2)
(engine warm)
#1-110, #2-107, #3-80, #4-100
Granted, looks like rings are worn, but shouldn't #3 and 4 still fire with this amount of compression? Always used to, till recently. Again, they ARE getting spark!
Should have mentioned, I swapped the plugs from 3 and 4 to 1 and 2, and put new wires on 3 and 4. Cleaned contacts on the cap--cap looks okay, is new. Maybe I should replace it anyway?
(quoted from post at 05:30:38 05/21/17)
Was it all working before? What happens if you put all the old parts back where they were originally?
I'm also intrigued why you swapped plug locations....
es
So I just swapped wires and distributor cap from other 8N that's running fine, and it runs exactly the same--still not firing on 3 and 4. BUT, I just realized that sparkplugs 3 and 4 don't go straight into the head like on my two other 8Ns--they go into a "riser" that is bolted into the sparkplug hole--what's this about? Is that because someone stripped out the sparkplug holes, and jury-rigged this to accept spark plugs? Must put the plugs 1/2 inch higher in the cylinder. Still, it ran fine until recently.
(quoted from post at 06:35:05 05/21/17) Okay, tried that--won't start at all the other way, so they must be correct--also, they match another 8N.
The evidence so far (anti-fouling adapters) points to oiling in cylinders 3 and 4, at least as a contributing factor, if not the root cause of your woes. Being as my first car was a '71 Vega, I'm well familiar with this problem. Did you thoroughly clean the plugs (all of them) before reinstalling? Even with the adapters, cleaning my plugs was a (short interval) maintenance item on the Vega until we rebuilt and sleeved the engine.
es
You may not be able to fix your problem short of an engine rebuild .
You may be able to help by using hotter plugs , Autolite 437 or Champ H - 12 I think , someone will be able to correct if those numbers are wrong .
Make sure you have a thermostat , preferably a 180 degree . You want the motor to run in the hot side of the normal range to help burn off the excess oil .
Make sure your air filter is clean and air is flowing freely . You do not want it gasping for air and sucking more oil around the rings .
Make sure your carb is not running rich and fuel fouling the system and compounding the problem .
Giving the motor a workout may help keep the oil burnt off or you may need to baby it depending on how bad the consumption is .
How much oil does it go through ? A quart per tank , two quarts every five gallons of gas ? Is it leaking oil also ?
Dave.......Ford specs: 90psi MINIMUM; good runnin N's 110psi; BRAND NEW N-engines 125psi. Those spacers are a "trick" fer oil burners. Raises the plugs outta the oil being pumped by the rings. Ford even sell'em p/n 2N12426. As fer yer sparkies; recommend AutoLite 437's gapped 0.025. 216's and H-10's (OEM) are too COLD and won't burn the OIL being pumped by the rings. BTW, 1-tps (1-oz) oil down the sparkie hole is way to judge the WEAR of the piston rings. +30psi is really WORN; +10psi is like new........HTH, Dell, yer self-appointed sparkie-meister
[b:c655426669]"1-tps (1-oz) oil"[/b:c655426669]
not sure what u meant by tps.
one ounce = two tablespoons (tbs,tbsp) = six teaspoons (tsp)
(quoted from post at 15:56:56 05/21/17) [b:9f4c2c53ad]"1-tps (1-oz) oil"[/b:9f4c2c53ad]
Could that be "The Plural Spoon" so you would need two ?
(quoted from post at 18:30:14 05/21/17)
(quoted from post at 15:56:56 05/21/17) [b:3671ff22b6]"1-tps (1-oz) oil"[/b:3671ff22b6]
ohhh, i hadn't thought of that. this is getting complicated now :)
a wiser man than i once said "one hippopotami cannot get on a bus, because one hippopotami is two hippopotamus."
yeah, 1-tablespoon = 3-teaspoons so I miss-abreviated tablespoon. The concept is the same, use some oil to seal the rings.........Dell
(quoted from post at 21:41:16 05/21/17) yeah, 1-tablespoon = 3-teaspoons so I miss-abreviated tablespoon. The concept is the same, use some oil to seal the rings.........Dell
ext time, just say a squirt or two....save some postings, but whizz off YT, due to reduced hit count!
Put two Al437s in it--gap them to about 3/16--go to work--if they foul
change them..There is no other Band-aid that will work better..
