Corn head grease
pixer
Question: I recently pumped my leaking steering gear full of corn head grease and I have some left, can I use to it grease my buddy bearings on my dual wheel tractor trailer and on zero fittings on my 47 8n.
Thanks for the grease info I'll put a new tube in with bearing grease not worth the risk to bearings if corn head not approved for bearings but just what is corn head grease made for? I'm not a farmer as you've probably figured out
(quoted from post at 12:08:22 05/23/17) but just what is corn head grease made for?
Straight from John Deere:
John Deere Corn Head Grease Video – CLICK HERE
Special-Purpose Corn Head Grease (AN102562, AH80490, TY24428)
Applications
Formulated for John Deere corn head and other slow-speed gear cases
Extra-soft grade of lubricating grease, required for row-unit gear cases of John Deere corn heads
-30 to 330°F (-34 to 165°C)
Service rating
·         NLGI grade 0
·         JDMJ13A5, J13E6, and J25A
Physical properties
·         Green color
·         Contains extreme-pressure additives
·         Excellent at high and low temperatures
·         Resists moisture and water washout
·         Polyurea thickened
·         Contains anti-rust properties
AN102562
Test analysis
Penetration @ 77°F (25°C), 60 strokes
355-385 mm/10
Dropping point, degrees F
450°F
Timken OK load, minimum
40 lb (18.1 kg)
Water washout @ 175°F, loss
10%
Oxidation pressure drop @ 100 hours, maximum
10 psi
