Are you suppose to be able to remove bearings , ie transmission input shaft bearing , and NOT mangle the cage so you could reuse the bearing ?
I have 5 8n transmissions disassembled plus lots of extra parts . I need to replace chipped gears and bad bearings / races . I can press off all of the bearings except the input shaft . I can get them off by not without distorting the frame that hold the roller bearings .
I know a new bearing is cheap but that is not the point . I have purchased a cheap bearing splitter set . Maybe I just need to do some relief grinding ? The cheap set worked smoothly .
http://www.ebay.com/itm/14p-Double-...m3ae39a1aa9&item=252926630569&vxp=mtr
