OT cultivator question
Rodeo man
I have an old Ferguson cultivator. Great size, it's a shade over 7' long. I only use it work up my ropin pen. I have lost/broken enough of the spring tines over the years, that it's rendered it pretty much useless. It's got 11 brackets, with heavy U bolts in it, where the tines should slide in. In the absence of replacement tines, would a large 18" piece of rebar suffice for my needs? I know they wouldn't have any angle on them, but would they tear the ground enough to meet my needs? I havent measured the holes the rebar would slide in, but it looks to be slightly over an inch. Maybe as big as an inch and 3/8 IDK. I always pull a heavy drag behind the cultivator.
(quoted from post at 18:19:40 05/09/17) I have an old Ferguson cultivator. Great size, it's a shade over 7' long. I only use it work up my ropin pen. I have lost/broken enough of the spring tines over the years, that it's rendered it pretty much useless. It's got 11 brackets, with heavy U bolts in it, where the tines should slide in. In the absence of replacement tines, would a large 18" piece of rebar suffice for my needs? I know they wouldn't have any angle on them, but would they tear the ground enough to meet my needs? I havent measured the holes the rebar would slide in, but it looks to be slightly over an inch. Maybe as big as an inch and 3/8 IDK. I always pull a heavy drag behind the cultivator.
I just had to come in and see how "Cultivator" could ever be OT! :D
As to your question and shooting from the hip . . .
maybe think vehicle or trailer leaf springs. You could take the biggest rod that will slide through as your shank and weld curved leaf spring pieces to them for sweeps.
I thought this monster would really rip, but it needs sweeps to pull it under. I started with the grey piece that I inherited and added the heavy brown railway rails. But this one would probably work for your ropin' pen.
(quoted from post at 05:04:01 05/10/17)
I had thought of welding box blade teeth to some rebar, that would fit in the hole. At $35 a tooth, that thought went away.
I would think rebar might bend too easy. How about railroad
spikes. You might be able to pick them up at a swap meet or flea
market.
Kirk
New Holland dealer sold me some of the spring shanks for my Ford cultivator which is the same as you Ferguson cultivator. My cultivator originally had a double leaf spring shank, the new ones are single but they are a direct replacement. The only problem I have had with them is that they look like steel but New Holland thinks they are made of gold. $$$
Railroad spikes are absolutely strong enough. I would put them on so the 'sharp' edge runs the same way as the tractor to reduce their desire to lift. When I was young I had a wonderful collection of railroad spikes - living close to the tracks improved my opportunity.
Maybe I needed more explanation... I had a section of u beam. I cut it into sections that looked like a 3 point implement. Mind you - it was heavy. I burned holes into the flat of the u beam and welded the spikes in. It works. You maybe would not want it to farm with, but it preps my deer plot. OBTW my welds will fail before the u beam - I am a rank amateur.
This is the part that throws me:
"I cut it into sections that looked like a 3 point implement."
Can't wrap my mind around that.
What does a 3-point implement look like? :D
T
(quoted from post at 07:19:40 05/10/17) I have an old Ferguson cultivator. Great size, it's a shade over 7' long. I only use it work up my ropin pen. I have lost/broken enough of the spring tines over the years, that it's rendered it pretty much useless. It's got 11 brackets, with heavy U bolts in it, where the tines should slide in. In the absence of replacement tines, would a large 18" piece of rebar suffice for my needs? I know they wouldn't have any angle on them, but would they tear the ground enough to meet my needs? I havent measured the holes the rebar would slide in, but it looks to be slightly over an inch. Maybe as big as an inch and 3/8 IDK. I always pull a heavy drag behind the cultivator.
The last one I had I parted it out and got more for it from the parts than I could as a assy... A local guy has one I looked at this week end he has not been able to sale I told him to part it out and keep the frame....
The frame is stout and should take what you can nail to it...
The nuts on the U bolts are hopelessly froze, and I'm out of oxy/acet. I ran it down to an Amish gentlemans house, that seems to specialize in fixing old and obscure machinery. He seemed confident that he could run down some tines that would work. No telling how long it will be in his shop, but I'd say it'll leave working.
