Drag link replacement and service
A-ford-able
New User
I've got what best I can tell used to be a 9n based on a few factors but mostly it's Frankenstein at best. Ive used as a mower and yard tractor as is for 5 years I've had it. This year things were too bandaged to ignore anymore and a rough idle turned into a full on tear down of multiple areas. So fast I've been fairly successful however it came with a box of parts that previous owner bought and never got around to using.
Among these parts were replacement front and rear tie rod ends. Mistakenly I thought this should be easy compared to making a new custom wire harness and restoring the distributors guts but I didn't know one side was threaded on both ends and the other has the rear end of the drag link fused to the tube and not threaded.
1. Is this normal to have the two different link types?
2. Whas the best way to "service" the fused end?
3. Should I just replace both with one that have threaded ends?
The box had 2 front and 2 rear tire rod ends so I have 4 new ends to use. .
Any education on the theories and original configuration as well as the makeup of the fused end is greatly appreciated!
For some uses the tractor needs to be widened out. The rear wheels have a dished center and offset hoops on the rim that allow 4 different widths for each wheel. The front axle then has multiple holes to allow it to be adjusted to match the width of the rear wheels. When the front it widened or narrowed the tie rods need to be adjusted to compensate for the change in length and this is done with the double threaded side. If you look closely at the threads you will find that one end is right hand thread, the other is left hand thread so you can turn the middle and that will shorten or lengthen that tie rod. Since tractors are low speed machines, one side is all that needs to be adjusted.
9N (39-47)and 8N (48-52) draglinks are different. Plus each side is set a different length. Define 'fused'. Tie rod ends go to the front. Thread into drag links. Get out your 39-53 MPC (Master Parts Catalog) and look at them. Add the fact too that on the 8N, the draglinks were different for the early steering box and then the later steering box. Who o knows what the previous owner left you.
I've seen a lot of those steering arms where the rear ball is not
replaceable in a short section. The only option I know of as far
as "servicing" one with a worn out rear end is to replace that
part of the arm or the whole arm.
I'm not sure if that section is available new any more.
Check out [b:85bc06eec0]John Smith's[/b:85bc06eec0] excellent ID section and you will
see many examples of them on the earlier tractors.
