Brian60950
Leaks gas out the hole in the bottom, .. sticking float, who knows. Ain't pulled it yet.
If I do, I'm going to need gaskets and possibly internal parts.
How do I determine it's model number for ordering parts? All I can see is the Marvel Schebler in the casting.
If I pull it off, I'll be needing at least one gasket.
If I clean off all that grease in search of a part number buried under it, I'll need to pull it apart to blow out all the solvent and stuff so I'll need more than just gaskets. I'm probably already in the tank for a float, needle, seat, etc.
2N, built in 1945.
Pay no attention to the barbed fitting sticking out the side, it's for a temporary gas tank. That's not where it leaks from.
Any idea what model number or where to look for identifying marks?
2N, built in 1945.
