deerslayer303
New User
Well YIPPEE today was the first time I could play with Mabel (my '48 8N) I changed the oil this morning and I decided to run some 15W40. To my surprise there wasn't even an oil filter in the canister :shock:. I got her all back together and decided I would pull the 4ft box blade for a while. She did good for about 15 minutes then all of a sudden she started skipping (sounded like I lost a cylinder) and wouldn't pull the box blade. So I parked her back under the shed and pulled the plug wires off one by one while running. #3 didn't change the tone of the motor, and #4 barely did. All 4 had spark to the plugs. Hmm, so I pulled out my compression tester and here are the results. Engine at operating temp. #1-105psi, #2-100psi, #3- just a tick over 75psi, #4-80 psi. I put all the plugs back in and fired it up, 10 psi oil pressure at idle and just 20 psi with throttle bumped to half way. She has 30 psi when cold, which is understandable, but I guess the real tell tale is when they are up to temp. I guess when buying an 8N don't run out and get all excited (like me) because she's pretty. Pretty sells, running good, doesn't. On another note though, the hydraulics are rock solid, no issues whatsoever. Will hold the HD box blade up for longer than I wanted to stand there and wait with the engine off. So I guess, Ole Mable is going to get a fresh engine. Heck she probably deserves it.
