Skip Burney
Well I am almost finished with my NEW block getting it ready to put together. I need to clean up the exhaust and intake ports a little more and lap the valves on THIS block and I will be good to go. I took out the oil gallery plugs before I vatted it and then cleaned everything out with carb cleaner and pulled a swab through it and reinstalled the plugs but I have a question for yall. I pushed out the old liners and my block looked really good I cleaned up the bores and measured everything and had between .003 and .005 interference. I pushed the new liners in and they went really well but when I measured the bores they were choked. The bore was spot on in the middle of the liner for new rings but the top and bottom of the new liner bores were about .005 below min. This could have either bound up the new rings in the ring grooves or scuffed the top and skirt of the piston. A few minutes with the hone and the bores are now straight top to bottom at min for new rings. Have any of you ever run into this? Also what do you put on the threads of the head bolts that penetrate into the water passages to seal them up.
