Muskellunge
I volt test my 6V pos ground batt and it reads 6.2. I press the starter button and get just clicks. I jump direct to starter and it starts right up. I run the tractor for an hour and get same results... tractor won't turn over without a jump.
When running, I volt test at the battery it reads 5.8... not running it reads 6.2. When I turn the ignition key on, ammeter does nadda...doesn't move. It also doesn't move much when tractor is running.. it bounces around slightly on either side of zero.
I'm not sure if the genny is bad or VR is bad....or what... any ideas?
Thanks,
Muskie
Thanks,
Muskie
