Kubota front rim
Tom N MS
Still need one for L1500 --same as L175 --never dreamed one would be so hard to find..Thanks for any and all help.
Tom,What is the tire size and number of holes and spacing,and center hole size?What is wrong with the original rim that it needs to be replaced?Did you try any of the salvage dealers that I posted before? I thought that one of them would have had a replacement.
Went oin circles trying to register so I could check the salvage yards--after hours of looking I'm ready to just forget it..Rim I have has three finger size hole rusted out at the stem hole ND OTHER RUSTED OUT EDGES IN 2-3 OTHER PLACES..mIGHT JUST HAVE TO TAKE IT TO LOCAL WELDING SHOP AND SEE IF THEY WILL EVEN MESS WITH IT AND JUST LEAVE THEM AN OPEN CHECK BOOK..iN DAYLIGHT WILL HAVE TO TRY TO MEASURE SOLE SPACING, CENTER HOLE ETC--GOING TO TRY TO ENTER THE SALVAGE YARD SITES AGAIN..
Got all the parts in and head picked up yesterday..Service manual was so large a file hadnt been able to print it yrt--Hope to print [ages needed right now and get it back together in next few days.
Tom, their is a guy here in Oregon that parts out those orange tractors. I can ask him if he has one. It will be a week before I see him tho. Let me know.
Here's one on Ebay for reasonable money. Make sure it's what you need. Click site below.
http://www.ebay.com/itm/70000-00028-FRONT-WHEEL-RIM-for-SEVERAL-KUBOTA-B-SERIES-L-SERIES-TRACTORS-/162483357727?hash=item25d4c3481f:g:m3AAAOxyc2pTbttD
Keep looking or fix your present wheel. I've fixed a lot worse.
Take the tire off the rim and measure rim diameter (which is on the tire), width, and bolt circle. Match it up to available Kubota rims. You have to take it apart any way whether you fix existing rim or replace it. Here's another rim on Ebay from TN. This one looks more like a Kubota Rim. It would be worth a phone call or an e-mail to this guy. Just get the info on your present rim first so you can confirm it will work for you.
http://www.ebay.com/itm/KUBOTA-TC030-11650-MX5100-FRONT-WHEEL-NO-TIRE/152406395281?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D41376%26meid%3D41649f2545c7439995b284ba8c9df946%26pid%3D100033%26rk%3D1%26rkt%3D8%26mehot%3Dlo%26sd%3D152406395281
(quoted from post at 23:05:42 04/19/17) Still need one for L1500 --same as L175 --never dreamed one would be so hard to find..Thanks for any and all help.
I didn't have any problem finding it. Assuming it's the same as an L175 the Kubota part number is 32150-11644 and available new from any Kubota dealer. Messicks quotes $105 plus shipping and 5-7 days delivery.
TOH
nO LUCK--SAYS OUT OF STOCK----REPLACED BY *****XXX** 0
AVAILABLE..mESSICK'SmIGHT JUST HAVE TO GO TO A DEALER--HATE TO ---cant even
mention L1500..BTDT yrs ago they wouldnt sell me an ORC so I just went
elsewhere-Ford dealer I think--it is just std 1-3/8 X 1-3/8 if I remember
correctly
(quoted from post at 19:33:29 04/21/17) nO LUCK--SAYS OUT OF STOCK----REPLACED BY *****XXX** 0
correctly
When I entered the 32150-11644 part number at Messicks online store it came up superceded by 32150-11640. Messicks says that new number is $110 and available in 5-7 days. I'm sure you can get it from just about any Kubota dealer for something close to that.
TOH
Thanks-I saw them and best I can tell they are for good bit bigger
tractors..will keep checking though,,Thanks
I do not know anything about this rims . Just got curious and did a search .
RIM, FRONT, 2 WD, 4 LUG, 12" X 3"
Manufacturer Part Numbers:
Various
32150-11640, 32150-11643, 32150-11644
