Hi
I have a 1962 Workmaster 631 and the hydraulic three point by is not working. We swapped the pump for another one which is a working pump. We injector air into the dipstick hole and we. Priced the air was coming out of the stick shift area. So we removed the plate holding the stick shift and then we re pumped air into the hydraulic dip stick hole and noticed that the air was bubbling the ?transmission? Fluid? Should air be leaking into the transmission fluid area? I took pictures and show with my pointed finger where the air bubbles out of. Please help if you have any idea on how to fix this.
thanks
Juan
thanks
Juan
