I have an 8n that I just recently finished rebuilding. It cranks right up and runs fine. If I pull the line to the pressure gauge off there
is oil flowing. I have a brand new pressure gauge installed, and the gauge reads 0 psi while the tractor is running. Admittedly I did not
do a very good job checking out the oil pump while I had everything torn down. I'm assuming I need to tear back into it and rebuild/replace
the pump, but I just wanted to verify no one else had any ideas before I go there.
