Hazmatt516
New User
Ive got a 8n with front mount distributor. It was running fine until i pulled carb and distributor off to put on a 2n im rebuilding just to get it running. The 2n ran for a bit then quit. I put everything back on mine and nothing, after checking a few things i got it running, kinda. It would idle smooth and run smooth at half idle. Three quarter and up to full it sputters and pops. Figured i picked up trash so i pulled carb apart and cleaned. Still same. I went ahead and replaced coil, points, and condensor, again just to make sure i didnt burn them up or something. Cap is new and so are plugs. It is a 6 volt system. Wires are decent. Points are gapped at 16. After all this still the same. Bought a new carb and still the same. The spark im getting is orange and not blueish white.
