1951 8N Progress
nashranch
slowly putting back together this 8N basket case i bought a while back. It is in good shape. Tranny and rear end has been gone thru i was told. I did not go thru engine cuz it doesn't have any ridge on the piston sleeves. I did pull the valves and lap them in.
(quoted from post at 22:01:48 04/09/17) slowly putting back together this 8N basket case i bought a while back. It is in good shape. Tranny and rear end has been gone thru i was told. I did not go thru engine cuz it doesn't have any ridge on the piston sleeves. I did pull the valves and lap them in.
(quoted from post at 18:42:15 04/10/17)
Got new wiring harness figured out today plus tires on it
Stay tuned for my work in progress..she runs good for a 1951 8N. It does blow a little smoke and has 30lbs. oil pressure. I'm hoping to get a video of it running on Youtube here in the next couple days
Blows a little smoke? I'd run it and work it.
Believe it or not, it worked for this 640.
I added a quart of ATF to the gas and worked it. YMMV
