poor n proud
I'm having problems once again.
This is a 12 volt - ground conv.w/ 12 volt coil and bypass safety starter button to a button to aftermarket push button on dash.
Went to start it,turned key to run .then pressing button on dash I Hurd a electronic popping sound from solenoid.so I continue to try to start it.it eventually turned the starter and tractor fired up.but the starter kept running. I turned the key to kill the tractor and engine stopped but starter kept running. I disconnected battery and starter stopped.
I went to napa with the three-point selenoid that was installed with my conversion. got a similar solenoid 12v, installed it .then reconnect battery, and starter didn't run when battery reconnected.so I thought everything was good.
Now I turn key ,push button on dash and I get nothing at all.no movement on amp meter nothing. I guess I need to get volt meter out and trouble shoot.
I'm not the smartest man when it comes to this stuff.if I need to take pics and post here if it will help I will .I just want to know where to start guys.
This is a great site I visit everyday.thanks to all that comment and all that have helped me before.
